  3. How to Inject Variable into pPar() for Parameter Sweep in...
  • Subscribers 136
  • Views 3354
How to Inject Variable into pPar() for Parameter Sweep in ADE Assembler?
baltaci
baltaci over 1 year ago
I use IC 23.1.
I’m trying to sweep a parameter in a cell using pPar, and I can’t get the variable injection to work as expected.
Setup
  • In my cell unitCapCell, I define a parameter like this:
    capValue = pPar("capOverride")
  • In my testbench tb_unitCapSim, I instantiate unitCapCell.
  • I create a global variable myCap in the Maestro view.
  • Then, in the instance of unitCapCell, I set:
    capOverride = myCap/64 (or simply myCap)
Problem
  • I want to sweep capOverride by sweeping myCap, but the value doesn't seem to propagate.
  • If I hardcode capOverride = 200f, it works — but then I can't sweep it.
  • If I use capOverride = myCap, the value isn’t passed to capValue.
Question
How can I correctly inject myCap into capOverride so I can sweep it at the top level?
Thanks for your help!
  • Saloni Chhabra
    Saloni Chhabra over 1 year ago
    It sounds like a setup problem and it'll be helpful to see images of the design and setup. Perhaps, you can start by referring to a working example with pPar here (it might resolve your issue) :
    Passing Parameters in the Schematic Hierarchy with pPar
    Saloni
