  3. Open Layout XL instead EXL by default
  • Subscribers 137
  • Views 4165
JH202504237643
JH202504237643 over 1 year ago
I tried to set  'graphic   maskLayoutDefaultApp   string  " Layout XL" ' , but it still remains Layout EXL without taking effect.
  • RobMan
    RobMan over 1 year ago
    This is probably due to the envear 'saveViewSubType'. The default is true. Meaning the layoutXL sub view type is saved and the default is to reopen in the XL tier.
    envSetVal("layoutXL" "saveViewSubType" 'boolean nil)
    Save the design, close, reopen; it should now default to 'L' (assuming you are using IC618).
  • RobMan
    Sorry, I just spotted you want XL tier. The same still applies.
  • JH202504237643
    JH202504237643 over 1 year ago in reply to RobMan
    Thanks, I have found the reason why it is not effective. It just doesn't work at 3nm.
    Andrew Beckett over 1 year ago in reply to JH202504237643
    EXL is required at 5nm and below.
