  3. simulation was terminated permaturely due to an error
  • Subscribers 136
  • Views 4190
HK202504284947
HK202504284947 over 1 year ago
Dear all,
I was using tran analyses to do post-layout simulation, however, the process meets the error in the spectre.out file as follow, could you please tell me how to fix it?
tran: time = 22.53 us (45.1 m%), step = 199.8 fs (400 p%)
tran: time = 22.53 us (45.1 m%), step = 7.302 ps (14.6 n%)
Fatal error found by spectre at time = 22.5265 us during transient analysis `tran'.
FATAL: internal error at sub_expand_search_inside_mim() in intm.c:831
Analysis `tran' was terminated prematurely due to an error.
Internal error found in spectre during transient analysis `tran'.
Encountered a critical error during simulation. Submit a Service Request via Cadence Online Support, including the netlist, the Spectre log file, the behavioral model files, and any other information that can help identify the problem.
FATAL (SPECTRE-21): Assertion failed.
Thank you very much
    Which Spectre sub-version are you using? (this will show up in the Spectre log; also "spectre -W" from the command line will tell you this). Which Spectre simulation mode are you using too? Spectre X? APS? XPS etc...
  • HK202504284947
    HK202504284947 over 1 year ago in reply to Andrew Beckett
    Thank you for your help, my spectre version is15.1.0.284.isr1.
    And I'm using XPS to do post-layout simulation to improve the speed.
    Andrew Beckett over 1 year ago in reply to HK202504284947
    Why are you using a 10 year old version of the simulator? It's highly unlikely that this issue remains in current, supported versions.
