  3. How to define Cell based on S-Parameters
  • Subscribers 136
  • Views 3520
spatz
spatz over 1 year ago
I want to EM simulate specfic layout parts of my circuit and use the resulting S-Parameters in my schematic and layout.
For example a CPW structure which connects the collector the input device and the emitter of cascode the device, which shall behave inductive.
For schematic I use an nport device, but I cannot use this for layout - LVS complains.
How to approach this?
I do not know what to look for in the documentation. If someone could give me a pointer and show me the way is very much appreciated!
Thank you!
  • Saloni Chhabra
    Saloni Chhabra over 1 year ago
    It's not entirely clear to me what you're trying to do. I assume you started with an LVS clean design, generated s-parameter for a layout and will simulate with this model. How is the nport model appearing in the LVS flow?
    Saloni
  • spatz
    spatz over 1 year ago in reply to Saloni Chhabra
    • Main cell A
    • EM simulated cell B:
      • schematic with nport and SP data
      • layout, which I used for EM simulation
      • symbol
    I put symbol.B in schematic.A and layout.B in layout.A.
    Now I want to perform LVS on layout.A. Then PVS will find the nport for layout.B and complains because from the connectivity view, layout.B is a short.
  • Saloni Chhabra
    Saloni Chhabra over 1 year ago in reply to spatz
    Setting Cell B as a blackbox during LVS should solve your issue. Can you view this article that explains the LVS options you need -
    PVS / Pegasus LVS to Quantus Blackbox Cell flow
    Saloni
