  3. Function to Detect Minimum Pulse Width
  • Subscribers 136
  • Views 2988
Kevin T Buck
Kevin T Buck over 1 year ago
I would like to implement something similar to the dyn_glitch check function as an expression in Explorer/Assembler. As far as I can tell this check function only exists from the command line but I'm trying to include a function as a group of outputs that will report the minimum pulse width for a specified signal. I'm trying to verify the functionality of some custom deglitching logic so I'd like to have a systematic check that reports the minimum pulse width at the circuit output.
  • Kevin T Buck
    I figured out that this is possible using the cross function with cycles as the print/plot vs. option.
