  3. adexl's "Run Simulation" always hidden when first open
  • Views 1250
dogman4
dogman4 over 1 year ago
Hi,friends
I'm using Virtuoso version 6.1.7-64b. When I open my Adexl, the "Run Simulation" and "Stop Simulation" buttons are always hidden and I have to expand them manually. Is there a way to make these buttons show by default?
I'm sorry, but I can't upload the pictures.
  • dogman4
    I'm sorry, but actually both of these buttons are hidden every time I open it, not just the first time.
    Andrew Beckett over 1 year ago in reply to dogman4
    Resize the toolbar to the size you want (i.e. to unhide the buttons) and then do:
    Window->Workspaces->Save As and then enter the name as (say) "Dogman" and OK the form.
    Window->Workspaces->Set Default and then pick "Dogman" as the default.
    I tend to prefer to leave "Basic" as-is (maybe however your "Basic" workspace has been messed up - you can check if you have a "Basic" workspace saved under .cadence/dfII/workspaces/adexl in (say) your work or home directory; you could then delete that and go back to the system default). The default should be at $CDSHOME/share/cdssetup/dfII/workspaces/adexl/Basic.workspace (you may not have $CDSHOME set - that's just a proxy for wherever your installation is).
  • dogman4
    dogman4 over 1 year ago in reply to Andrew Beckett
    it works,very thanks Andrew
