  3. Probing current of an instance using hidden supply pins
  • Subscribers 136
  • Views 3129
Volker T
Volker T over 1 year ago
Dear all,
I would like to probe the current of an instance using hidden pins (having its voltage net assigned to by a netSet property). There is a soltution for probing the current of an instance using inherited pins, that does not work in my case, for some reason (see probing current through an inherited pin).
I use SpectreX and ADE Assembler with Virtuoso Studio IC23.1-64b-ISR727.
The scenario is having a standard cell, containing mutiple other standard cells.
I am interested in the supply current of the top standard cell.
The top standard cell (hierarchically instance /TOP/I1/I2 in the test bench)  itself has no supply pins at all, and contains only other standard cells without supply pins at their symbols.
Only the schematics of the standard cells at most bottom level contain "hidden pins", i.e. an I/O pin with a name like "vdd5" and a net expression attached (like Property Name = vdd5, Default net = vdd5!, Evaluated net vdd5!, for which there is no pin available in the symbol (achievable by activating the "Exclude Inherited Connection Pins" option when creating the symbol view from schematic view)..
Now, I tried several things to probe the current of vdd5 of cell /TOP/I1/I2:
  • Using Outputs→Add→OP Parameters. This does not work even when I just type in the hierarchical path and pin name/property name/whatever. After typing in any text, ADE Explorer simply deletes it, probably, because it's an illegal expression from its point of view.
  • Using a "save" statement in an .SCS file, again using the hierarchical path plus pin name, separated by a colon (like "save TOP.I1.I2:vdd5"). Using the property name instead of the pin name, or the net name of the net attached by the netSet does not work either.
For plotting the current, I tried both OT("/TOP/I1/I2" "vdd5") and IT("/TOP/I1/I2/vdd5"), again also trying pin name, property name and assigned net name. Nothing works.
So, how can I probe the standard cell's current, if all of the above fails to work? (Modifying the circuit is not allowed.)
Thank you!
  • Volker T
    Okay, the solution is already stated in Andrew Beckets answer of the above linked post.
    One needs to look up the net name as used in the spectre netlist. It is a different name of what I can see on schematics level. Then it works!
