  3. Simulation from an imported CSV file
  • Subscribers 136
  • Views 3062
JB202507023247
JB202507023247 over 1 year ago
Hello Sir,
I was wondering if there's a tutorial or something for a way to simulate and get graphs of a CSV file of voltage over time imported to cadence ?
I tried vpwlf and vpwlfm but both don't work.
Error CMI 3035 syntax in waveform file .
Ensure that the time values are entered in pairs w each pair specified in separate line.
But already the CSV has only one column for time
Thank you
  • Saloni Chhabra
    Saloni Chhabra over 1 year ago
    Do you want to view the signal defined in .csv, or use this signal to drive a circuit in Spectre?
    You can try loading this .csv into ViVA and see if you get the expected waveform. From ViVA, you can also export out a 'VCSV' format file (click on the trace -> Send to -> Export). This file can be used with vpwlf source in Spectre.
    Saloni
