  3. How to use schematic view of a sub-circuit and extracted...
  • Subscribers 136
  • Views 2711
How to use schematic view of a sub-circuit and extracted view of everything else
Aks23
Aks23 over 1 year ago
I have changed the device parameter in one of sub-circuit and would like to use this in 'schematic view' and everything else in extracted view. I do not have individual extracted views of the other circuits so that I can use the config view window and change the instance type. Does anybody have an idea here?
  • Saloni Chhabra
    Saloni Chhabra over 1 year ago
    Is this sub-circuit that has been changed (and you want to use its schematic view) already extracted as part of your extracted view? If yes, then you won't be able to achieve what you've described. Extracted outputs are flat, which means that the subcircuit hierarchy isn't preserved. If you can re-run extraction with this particular sub-circuit black-boxed, you can choose to use its schematic view from config view.
    Here's a short video which explains this flow -
    PVS QRC Blackbox Flow for AV Extracted View (Video)
    Saloni
