  3. Get test's temperature without leaving assembler window
  • Views 703
dogman4
dogman4 over 1 year ago
Hi,friends
Is there a way to quickly get the temperature information set by a test in explorer without leaving the assembler window?
like:
When I place the mouse pointer over the test in the assembler, a floating window appears on the test and some information is displayed in the following format:
Tool   :ADE
Design  :xxxx
Is there a way to add the temperature information corresponding to the test on this pop-up floating window?
thx in advance
virtuoso version:@(#)$CDS:virtuoso version 6.1.8-64b 09/03/2024 19:11 (sjfhw316) $
    maeGetSimOption("AC_ONLY" ?option "temp") ; AC_ONLY is the test name in my case
    No. Well, you could add the temperature as a note to the test using axlPutNote, but you'd have to then somehow keep it in sync, and I don't think there's any trigger when the temperature is changed. Note also (with both of these) that if the temperature is set in a corner, the test temperature wouldn't reflect that (as it's changed at simulation time).
