  3. Parasitic Extraction (PEX) - Tool Migration from IC6 to...
  • Subscribers 136
  • Views 1103
Parasitic Extraction (PEX) - Tool Migration from IC6 to IC23
ranaya
ranaya over 1 year ago
Dear All,
I have been using IC6 for DRC/LVS and PEX for some time and due to technical reason, I had to migrate to IC23.0 version. I am quite familiar with the IC6 PEX procedure of generating a parasitic netlist from the layout as show in the following steps.
https://limewire.com/d/WIaaC#70NCOnHMWU
Now in IC23, the PEX setup and GUI window is different. The interface looks like below:
https://limewire.com/d/uqaxq#VZ8CXqHu1u
After I enter all details, ran a PEX round and the report created after the run is shown below:
https://limewire.com/d/b7kPo#fUDm9v8mPZ
However I didn't get any window similar to the "Calibre View Setup" of the IC6 design flow in IC23 PEX flow.
Can anybody help me to resolve this issue ? I just want to generate a parasitic netlist and a .subckt from this netlist, so that it can be used as a circuit.
Thanks and Cheers
Anuradha
    Anuradha,
    Calibre is not a Cadence tool - it's from Siemens EDA. You should speak to them about this...
