  3. Tolerance relaxation when calculating DC operating point...
  • Subscribers 136
  • Views 1546
Tolerance relaxation when calculating DC operating point - impact on accuracy of SP analysis
Macio
Macio over 1 year ago
I have a general question on SPECTRE-17191 warning:
Warning from spectre during DC analysis `dcOp'.
WARNING (SPECTRE-17191):
Tolerance relaxation is used to obtain final DC solution which may affect the accuracy of the result. This is mainly caused by the high impedance nodes in the circuit. Use the dyn_highz check to determine the high impedance nodes. Setting/assigning appropriate initial values to these nodes will usually help to improve both performance and accuracy of DC simulations.
I would like to obtain high accuracy results from SP analysis (~70dB level) for an RC extracted block. I am using SpectreX CX accuracy with advanced options enabled: Preset Override = reltol(1e-4), Parasitic Optimization = OFF.
My concern is that when relaxation is used to obtain the DC operating point for the S-parameter analysis, the accuracy of the final results is impacted.
Is there a quantitive way to approximate how much influence relaxation has on the results?
Spectre version: 24.10
Thank you,
Macio
    Andrew Beckett over 1 year ago +1
    Macio, The chances are that it doesn't influence the sp results significantly - it might mean a small difference in the DC operating point, but that usually wouldn't impact the s-parameter simulation…
    Macio,
    The chances are that it doesn't influence the sp results significantly - it might mean a small difference in the DC operating point, but that usually wouldn't impact the s-parameter simulation too significantly.
    However, we don't have good guidance on the impact of this specific message - I've seen a request for greater clarity on this specific warning from a colleague, but R&D haven't given feedback yet. I would suggest you contact customer support (submit a support case using the Case menu after logging in).
  • Macio
    Macio over 1 year ago in reply to Andrew Beckett
    Thank you Andrew!
