  3. spectre assert
  • Views 3079
spectre assert
Joe Mellon
Joe Mellon over 1 year ago
Hi, can anyone tell me how to exclude subckts in spectre assert statement? Just like "xsubckt=..." in checklimit statement or any other...
Joe
  • Joe Mellon
    Joe Mellon over 1 year ago in reply to Andrew Beckett +1
    Hi Andrew, Sorry for the late reply - I was away on vacation and just got back. Quick update: 1, Tried "param=skip_dev_inside_subckt value=[inv1]" in my case - Didn't behave as expected. 2, Dug deeper…
    Joe,
    I'm not sure this is possible. There is (in theory) this:
    mycl checklimit asserts=[testassert] param=skip_dev_inside_subckt value=[inv1]
    but I can't get it to work. I think the skip_dev_inside_subckt (see "spectre -h assert") only makes a difference for certain types of assert.
    I suggest you contact customer support so that a fuller investigation can be made and an enhancement filed if needed.
  • Joe Mellon
    Quick update:
    2, Dug deeper into the "skip_..." options mentioned, and finaly found a workaround in the "Spectre Circuit Simulator Reference" manual: "checklimit_skip_insts=[...]"
    3, Added an option line in my netlist:
    myclopt options checklimit_skip_insts=[inv1]
    It works perfectly now, exactly as needed. Hope this helps others facing similar issues!
    Really appreciate you taking the time!
    Cheers,
    Joe
