  3. Generate steamOut.map for Innovus GDS export in Virtuoso...
  • Subscribers 136
  • Views 3210
Generate steamOut.map for Innovus GDS export in Virtuoso?
Gurjot Singh
Gurjot Singh over 1 year ago
Is it possible to generate steamOut.map that is needed during Innovus GDS export in Virtuoso, where that PDK is already working. I have several PDKs in virtuoso but their streamout.map files are dificult to locate or doesnt work well when used in innovus.
So can i generate map file reliably in virtuoso, then feed to innovus?
Also, if i have stream out file from synopsys tool - (ICC GDS Out Map file), is there a way to convert it to Innovus Compatible?
    See How do I read in a Stream file generated by SOC Encounter/Innovus into Virtuoso? Resolve XSTRM-158 warnings while trying to import a GDS file
