  3. Loading *WARNING* Connection to MACHINE failed. Connection...
  • Subscribers 136
  • Views 3176
Loading *WARNING* Connection to MACHINE failed. Connection refused
hesaliveJim
hesaliveJim over 1 year ago
Whilst starting PVS I get
cadence virtuoso IC23.1
Loading prf.cxt
This also appears on icfb startup:
The Health Monitor tool is installed. You can access it from CIW - Tools - Diagnostic Center or use the shell command 'cdsPerfDiag -p 5251' to open it when Virtuoso freezes.
Loading diagCenter.cxt
Wondering what it could be? - Centos 7 OS
    Take a look at this: Not able to open PVS Run Submission form - *WARNING* Connection failed
  • hesaliveJim
    hesaliveJim over 1 year ago in reply to Andrew Beckett
    Thank you I cannot access that directly - could I have a summary please?
    Andrew Beckett over 1 year ago in reply to hesaliveJim
    I'm getting an error when I try to post the details. Can you not log into our support site?
  • hesaliveJim
    Thank you yes I believe I have now sorted it.
