  3. ADE ViVA Plotting Template: Where is it stored and how to...
  • Subscribers 136
  • Views 3335
ADE ViVA Plotting Template: Where is it stored and how to edit?
StephanWeber
StephanWeber over 1 year ago
I want to make more use of plotting templates. However, I wonder, where are templates stored? Can I use them easily in the next design proj?
And most, can I edit them manually in a text editor?
If the syntax is easy to understand, then manual modifications in a text editor are likely much faster than loading the results, modifying setup in GUI and store again.
The Save as CSV function for output setup is cool, hope the plotting template becomes as useful as this, because some plotting defaults are very weird in ADE, like plotting a signal puts AC, DC & TRAN into one plot, or different tests go to different tabs, so that e.g. comparing Vout for pre-trim and post-trim is hard (or almost impossible because after manual copy both have likely the same style, name, color, etc.).
Bye Stephan
    Within the maestro view, because they are specific to the tests and outputs in the view.
    You could, although this is not recommended. The syntax is not documented. The intention is that it's generally fairly easy to arrange the results graphically as you want them and then capture that rather than this being a scripted way of plotting results.
    That's exactly the point of plotting templates. The defaults are what they are - and changing them is always going to upset someone (it wouldn't put AC, DC and TRAN into one plot though, because they have different axes/different units, so that's a bit surprising). The plotting template is intended that you can arrange the graphs as you wish once and re-use them.
  • StephanWeber
    StephanWeber over 1 year ago in reply to Andrew Beckett
    Thanks Andrew for fast & detailed answers!
    My initial thought was that the template files are easier to access, e.g. the "Documents" part in the Data View assistant would be a nice place.
    Bye Stephan
