  3. Automatic routing using Cadence Virtuoso IC6.18.120
  • Subscribers 136
  • Views 2483
hoangtn3702
hoangtn3702 over 1 year ago
Dear all,
I am trying to do automatic routing with the GUI command "Route --> Automatic routing --> All nets" using Layout GXL but there are still incomplete nets. My layout is generated from the schematic using "Connectivity --> Generate --> All from source" and then automatic placement with "Placement --> Analog --> Automatic placement". Did anyone have this problem before? Or am I using these commands in a wrong way? Do you have any other suggestions for the automatic routing?
Also, when I look up the command for automatic routing in the Cadence Virtuoso IC6.18.120 user manual, I cannot find the "Route --> Automatic routing --> All nets". Does anyone have any idea for this?
I would appreciate all your help.
Thank you very much,
Hoang.
