  3. Verilog A: Generate different $random values for each Monte...
  • Subscribers 136
  • Views 4368
Verilog A: Generate different $random values for each Monte Carlo iteration
MC20250412421
MC20250412421 over 1 year ago
Hi everyone !
I have a Verilog A block that uses the $random function as is (without any seed defined inside the Verilog A code). I have noticed while running Monte Carlo (default settings) that the Verilog A would always generate the exact same $random values for each MC iteration.
I assume it is because the Monte Carlo seed which is 12345 is being fed into the Verilog A $random function ?
If that's the case, what is the best way to generate $random values that are different for each MC iteration ?
Thanks in advance for your answers !
  • JankoK
    JankoK over 1 year ago +1
    Hi, Interesting question... I guess you could do something similar to this: How to do Monte Carlo mismatch variation on a VerilogA model That model deck is just a separate .scs (model file) where…
    Andrew Beckett over 1 year ago in reply to JankoK +1
    Janko's proposal is probably the best solution, but another way could be to use How to pass the monte carlo trial (iteration) number to VerilogA module? - this could then be used to set the seed per iteration…
  • JankoK
    That model deck is just a separate .scs (model file) where you add your statements (don't forget to include it in you Model Libraries). You can also define process{} too, for process variations, under that statistical statement.
    Let me know if it worked.
    Disclaimer: I have not tried this myself.
    BR
    /Janko
    Janko's proposal is probably the best solution, but another way could be to use How to pass the monte carlo trial (iteration) number to VerilogA module? - this could then be used to set the seed per iteration.  That approach is better if your model is producing a sequence of random numbers rather than modelling a local/global variation effect.
  • MC20250412421
    MC20250412421 over 1 year ago in reply to JankoK
    Thanks a bunch for that answer !
    While Andrew's answer was a simpler solution for my problem (just having a different seed for each MC run), you showed me something I had no idea how to do before and that I'll be using from now on.
    So again, thanks a lot for that and have a great day !
  • MC20250412421
    MC20250412421 over 1 year ago in reply to Andrew Beckett
    Thanks a lot !
    Your solution was the simplest for my $random problem (just having a different seed each MC run) so I went with it. Though the values aren't as random as I would like since the seeds are known and using this technique on single runs will always return the same $random values. I was wondering if there was a more volatile environment variable that could be read from verilog A, perhaps something like unix time ?
    No worries if such a thing doesn't exist, I'm just curious if you know something.
    Have a great day !
    Andrew Beckett over 1 year ago in reply to MC20250412421
    Normally people want repeatability in simulations over being different on every run, but you could use $simparam("systime") to get a time-based value (and maybe combine this with the iteration number) as covered in How can you access the current date from a system call in VerilogA?
  • MC20250412421
    Really cool !
    This was what I was looking for.
    Thanks a lot : )
