  3. Automating Library Reference Change with Additional Parameters...
  • Subscribers 136
  • Views 2266
Automating Library Reference Change with Additional Parameters in New Library
AN202507174258
AN202507174258 over 1 year ago
I am working on a schematic where I need to change the library reference of certain instances from one library to another. For example, in my library “ABC” I have an instance A1 that currently comes from library A. In library A, the cell has parameters w and l.
In the newer library B, the same cell A1 has parameters w, l, and an additional parameter xyz. What I would like to do is:
  • Update the library reference for all occurrences of this instance so that they point to library B instead of library A.
  • Retain the existing values of w and l from the old instance.
  • Initialize the new parameter xyz as a variable (so that I can later sweep or change it during simulation).
I know this can be done manually through “Change Library Reference” in Library Manager and then editing the parameters in the instance properties form. However, since I have many such instances across my schematic, doing this manually is not practical.
Is there a way to achieve this using a SKILL script, so that the process of:
  1. Changing the library reference,
  2. Copying over the existing parameters, and
  3. Setting the new parameter to a chosen variable name
…can be automated?
Any guidance, examples, or references would be greatly appreciated.
Best regards,
Azmaeen
