  3. Quantus QRC issue
  • Subscribers 136
  • Views 3507
Quantus QRC issue
HY20250821344
HY20250821344 over 1 year ago
Hi
I am now working on the QRC & voltus-fi EMIR flow. And I find some issue when I work on the QRC extraction.
Environment details:
PDK: Samsung 90nm
Virtuoso version: IC23.1
QRC version: 21.1.1-s329
Calibre version: v2023.3_14.8
My flow is: Calibre LVS -> Calibre Query -> QRC -> ADE simulation with EMIR option
I have tested the flow with a simple INV and all the flow can run successfully. Now I tested it on a Bandgap and the QRC extraction failed when extracted the poly resistor. I attached the error as following:
# Reconnect RES devices
createLink opppcres_0term opppcres_0dev_0tw-48_rvia
createLink ppwell opppcres_0dev_0tw-48_ppwell_rvia
reconnect -V -xdspf -I'#' -se2 rwires.res -n NET -r \
        opppcres_0dev_0tw-48.respppcres_0dev_0tw-48.resr \
        opppcres_0dev_0tw-48 \
        opppcres_0dev_0tw-48_rvia,opppcres_0dev_0tw-48_ppwell_rvia
ERROR (RECONN-157025): 'opppcres_0dev_0tw-48_rvia' is not a flat edge file
Any suggestion on how to fix it? Thanks.
    This might help: ERROR (RECONN-157025): layer is not a flat edge file (you might want to contact the foundry though to ensure everything is synchronised).
  • HY20250821344
    HY20250821344 over 1 year ago in reply to Andrew Beckett
    Thanks for the help. It's now OK.
    Just summarize for someone who may face the same issue in the future.
    Reason: opppcres is only defined in the LVS rules but  not defined in the lvsfile(in the QRC tech file folder).
    Solution: add the opppcres definition in the lvsfile and QRC can run successfully.
