  3. Could not find netlist procedure:SpectreFNPairs instanc...
  • Subscribers 136
  • Views 2518
Could not find netlist procedure:SpectreFNPairs instance
ranaya
ranaya over 1 year ago
Dear All,
Hi, I am running into an issue in my Cadence netlist simulation. It looks like below:
Begin Incremental Netlisting Sep 1 14:58:41 2025
Netlist Error: Could not find netlist procedure:SpectreFNPairs instance "V16" in cell-view "UMC65_TEST" "tspc_testing_time_det" "schematic"
Netlist Error: Could not find netlist procedure:SpectreFNPairs instance "V3" in cell-view "UMC65_TEST" "tspc_testing_time_det" "schematic"
Netlist Error: Could not find netlist procedure:SpectreVPWLSource instance "V5" in cell-view "UMC65_TEST" "tspc_testing_time_det" "schematic"
Netlist Error: Could not find netlist procedure:SpectreVPWLSource instance "V4" in cell-view "UMC65_TEST" "tspc_testing_time_det" "schematic"
Netlist Error: Could not find netlist procedure:SpectreFNPairs instance "V6" in cell-view "UMC65_TEST" "tspc_testing_time_det" "schematic"
Netlist Error: Could not find netlist procedure:SpectreFNPairs instance "V2" in cell-view "UMC65_TEST" "tspc_testing_time_det" "schematic"
Netlist Error: Could not find netlist procedure:SpectreFNPairs instance "V8" in cell-view "UMC65_TEST" "tspc_testing_time_det" "schematic"
End netlisting Sep 1 14:58:42 2025
ERROR (OSSHNL-514): Netlist generation failed because of the errors reported above. The netlist might not have been generated at all, or the generated netlist could be corrupt. Fix the reported errors and regenerate the netlist.
Can anyone help me to sort this out?
Thanks in advance
Anuradha
    Anuradha,
    These are (presumably) functions that should be provided via the libInit.il of the library containing the instances. They sounds like voltage sources, but these are not Cadence-provided sources (the function names are not ours). I would check whether these V2, V8 sources etc are from some custom library and if there's some SKILL code or context file that is not being loaded? Maybe the library was copied or renamed and so the associated code is not being loaded?
    You should contact whoever provided that library.
  • ranaya
    ranaya over 1 year ago in reply to Andrew Beckett
    Mmm.... this could be due to the inclusion of a wrong library.
    How does the typical path to the analogLib in Cadence package look like ? May be I am sourcing a wrong library.
    i.e. /remote/labware/packages/cadence/ic/23.10.060/tools.lnx86/dfII/etc/cdslib/basic ??
    Thanks.
    Andrew Beckett over 1 year ago in reply to ranaya
    The best approach is to use this in your cds.lib :
    DEFINE analogLib $(inst_root_with:tools/dfII/bin/virtuoso)/tools/dfII/etc/cdslib/artist/analogLib
    this will pick up analogLib from the same installation as the Virtuoso you are using.
    Perhaps you're using some modified analogLib set up for a different simulator?
  • ranaya
    Well actually that definition leads to the same path, however it is from a synopsys package Astonished
    i.e. /.../packages/synopsys/embedit/W-2024..../auxx/samples/analogLib
    The persisting error looks like below:
    Reusing AHDL Data dir
    generate netlist...
    Loading hnlInit.cxt
    Loading seCore.cxt
    Initializing the control file using cp:
    cp /remote/labware/packages/cadence/ic/23.10.060/tools.lnx86/dfII/etc/si/control.spectre /home/x3010318/remote_home_x3010318-Moved.d/Cadence_Sim/UMC65_TEST/tspc_testing_time_det/maestro/results/maestro/Interactive.4/1/UMC65_TEST_tspc_testing_time_det_1/netlist/control
    Copying Spectre source file 'spectre.inp'
    Copying Spectre command file 'spectre.sim'
    Begin Incremental Netlisting Sep 4 12:11:35 2025
    Netlist Error: Could not find netlist procedure:SpectreFNPairs instance "V0" in cell-view "UMC65_TEST" "tspc_testing_time_det" "schematic"
    End netlisting Sep 4 12:11:36 2025
    ...unsuccessful.
    *Error* failed at creating netlist
    *Error* geqp: can't handle (nil >= 1)
    *Error* geqp: can't handle (nil >= 2)
    *Error* geqp: can't handle (nil >= 3)
    *Error* geqp: can't handle (nil >= 4)
    *Error* geqp: can't handle (nil >= 5)
    *Error* geqp: can't handle (nil >= 6)
    *Error* geqp: can't handle (nil >= 7)
    CDF: An error occurred when evaluating callback.
    Callback: hbmag1->use => cdfgData->hbtones->value >= 1
    Message: *Error* geqp: can't handle (nil >= 1)
    Callback: hbphase1->use => cdfgData->hbtones->value >= 1
    Callback: hbharm1->use => cdfgData->hbtones->value >= 1
    Callback: hbtone1->use => cdfgData->hbtones->value >= 1
    Callback: hbmodharm1->use => cdfgData->hbtones->value >= 1
    Callback: hbmodtone1->use => cdfgData->hbtones->value >= 1
    Callback: hbmag2->use => cdfgData->hbtones->value >= 2
    Message: *Error* geqp: can't handle (nil >= 2)
    Callback: hbphase2->use => cdfgData->hbtones->value >= 2
    Callback: hbharm2->use => cdfgData->hbtones->value >= 2
    Callback: hbtone2->use => cdfgData->hbtones->value >= 2
    Callback: hbmodharm2->use => cdfgData->hbtones->value >= 2
    Callback: hbmodtone2->use => cdfgData->hbtones->value >= 2
    Callback: hbmag3->use => cdfgData->hbtones->value >= 3
    Message: *Error* geqp: can't handle (nil >= 3)
    Callback: hbphase3->use => cdfgData->hbtones->value >= 3
    Callback: hbharm3->use => cdfgData->hbtones->value >= 3
    Callback: hbtone3->use => cdfgData->hbtones->value >= 3
    Callback: hbmodharm3->use => cdfgData->hbtones->value >= 3
    Callback: hbmodtone3->use => cdfgData->hbtones->value >= 3
    Callback: hbmag4->use => cdfgData->hbtones->value >= 4
    Message: *Error* geqp: can't handle (nil >= 4)
    Callback: hbphase4->use => cdfgData->hbtones->value >= 4
    Callback: hbharm4->use => cdfgData->hbtones->value >= 4
    Callback: hbtone4->use => cdfgData->hbtones->value >= 4
    Callback: hbmodharm4->use => cdfgData->hbtones->value >= 4
    Callback: hbmodtone4->use => cdfgData->hbtones->value >= 4
    Callback: hbmag5->use => cdfgData->hbtones->value >= 5
    Message: *Error* geqp: can't handle (nil >= 5)
    Callback: hbphase5->use => cdfgData->hbtones->value >= 5
    Callback: hbharm5->use => cdfgData->hbtones->value >= 5
    Callback: hbtone5->use => cdfgData->hbtones->value >= 5
    Callback: hbmodharm5->use => cdfgData->hbtones->value >= 5
    Callback: hbmodtone5->use => cdfgData->hbtones->value >= 5
    Callback: hbmag6->use => cdfgData->hbtones->value >= 6
    Message: *Error* geqp: can't handle (nil >= 6)
    Callback: hbphase6->use => cdfgData->hbtones->value >= 6
    Callback: hbharm6->use => cdfgData->hbtones->value >= 6
    Callback: hbtone6->use => cdfgData->hbtones->value >= 6
    Callback: hbmodharm6->use => cdfgData->hbtones->value >= 6
    Callback: hbmodtone6->use => cdfgData->hbtones->value >= 6
    Callback: hbmag7->use => cdfgData->hbtones->value >= 7
    Message: *Error* geqp: can't handle (nil >= 7)
    Callback: hbphase7->use => cdfgData->hbtones->value >= 7
    Callback: hbharm7->use => cdfgData->hbtones->value >= 7
    Callback: hbtone7->use => cdfgData->hbtones->value >= 7
    Callback: hbmodharm7->use => cdfgData->hbtones->value >= 7
    Callback: hbmodtone7->use => cdfgData->hbtones->value >= 7
    You need to fix your installation. There shouldn't be anything from Synopsys in the IC installation - my guess is that you have some kind of linked installation with bits linked to something from Synopsys (maybe to accommodate one of their simulators). You should use a native installation or reinstall. If you are trying to use Spectre, don't use some installation that has been hacked around...
