  3. .proc file for TSMC65 for the EMX simulator
  • Subscribers 136
  • Views 4678
GL202502244954
GL202502244954 over 1 year ago
Hi, could someone help me with how to get the .proc file for TSMC65 for the EMX simulator?
    Please contact customer support. Use the Case menu to submit a case after logging in.
  • GL202502244954
    Hello, thank you very much for your help. I already have the .proc files for different corners. However, when I look for them in the simulation environment section with EMX, they appear but I am not able to select them.
    Andrew Beckett over 1 year ago in reply to GL202502244954
    Did you log a support case? If so, please ask this question there (otherwise I'm not sure how you got hold of the proc files or the script to generate them from the foundry-supplied data).
    It rather depends on which interface to EMX you are using (you didn't say, and didn't way which version of EMX or IC you are using either).
  • GL202502244954
    GL202502244954 over 1 year ago in reply to Andrew Beckett
    Thank you, I will reach out to support directly.
