  3. Does Cadence provide a standard Python API for tool automation...
  • Subscribers 137
  • Views 7522
Does Cadence provide a standard Python API for tool automation?
WM20250906725
WM20250906725 over 1 year ago
Does Cadence have a standard Python interface, similar to how Cadence has an interface with MATLAB?(Is there a Python interface for Cadence Virtuoso?)
    We have Python interfaces for specific things - for example:
    • There is something called CDSPYTHONSRR which was introduced in IC23.1 ISR12 (it was available as a standalone kit on request before that) which allows you to read simulation results directly into Python. This doesn't cover everything that you can do with the MATLAB interface, and there's no integration into ADE (so you can't have python expressions in the output). There's an enhancement CCR for that - 2052789 - with a few duplicates. If this is what you want, you should contact customer support (submit a case after logging in) and request a duplicate is filed on your behalf.
    • There is a capability with Spectre (Spectre Interactive) which allows Spectre to be controlled using Python or Tcl
    • The Advanced Optimisation Platform provided as part of the Virtuoso Variation Option or ADE Artist gives the ability to integrate a custom optimiser algorithm using C++ or Python.
    There is not a general Python interface that can be used to customise Virtuoso though; the customization language is and remains SKILL.
  • WM20250906725
    WM20250906725 over 1 year ago in reply to Andrew Beckett
    Thanks! Would you tell me that where can I find Python interfaces for Spectre? I found a similar one on https://github.com/AugustUnderground/pyspectre?tab=readme-ov-file and I don't know if there are any better Python interfaces for Cadence Spectre.
    Andrew Beckett over 1 year ago in reply to WM20250906725
    Yes, that's an old interface that takes advantage of the SKILL interface into spectre (which has been around for many years). Ours is more tightly integrated and has greater control.
    The access requires a particular license, and the documentation is provided on demand - so please contact your account team if you are interested.
  • RP202509273923
    RP202509273923 over 1 year ago in reply to Andrew Beckett
    Andrew, I am looking for documentation on the Python interface to spectre. It is listed in the product list as:
    Interactive mode for Spectre using Python/TCL, Part #38530
    Can you please help me find this reference?
    Rachael
    Andrew Beckett over 1 year ago in reply to RP202509273923
    Hi Rachael,
    Please contact customer support (use the case menu to submit a case after logging in). For various reasons, the documentation for this interface is not included in the main documentation, so it is provided on demand to those who have the product.
