  3. How to rerun just one test of a simulation with 2 test and...
  • Subscribers 138
  • Views 3507
How to rerun just one test of a simulation with 2 test and variable dependency
Pedrocasty
Pedrocasty over 1 year ago
Hello everyone! Today I found a question that I couldn't solve by myself. I fail preparing a sim in maestro. This sim has two test. TEST A who calculate a code of trimming  and TEST B who use this values to calc whatever. So, the problem is the TEST B where i didn't' define properly the transient analysis. I want to rerun the sim but TEST A is really long in general so, the perfect solution for me is to keep TEST A results and just rerun TEST B to fix my error. Have you got an idea of how to do it, indeed, It is possible to do it??
  • revida marcos
    revida marcos over 1 year ago
    Yes, extract trimming codes from Test A's results, set as fixed vars in Test B setup, then right-click Test B in Maestro and run selected only.
  • Pedrocasty
    Pedrocasty over 1 year ago in reply to revida marcos
    could you explain it step by step. I can't find the options in the menu from maestro
  • Yagya Mishra
    Yagya Mishra over 1 year ago
    It is possible with calcVal() implemented in TestB. Assuming your simulation is complete and TestA results are available in Interactive.0
    Let's also assume 'code of trimming' is the value of output trimCode. You want to use the value of trimCode over TestB
    trimCodeValue (variable in TestB) = calcVal("trimCode" "TestA" ?historyName "Interactive.0")
    Disable TestA and re-run TestB
