  3. Signals not saved properly using "Save by Subckt"
  • Subscribers 136
  • Views 4655
dtodorov
dtodorov over 1 year ago
I am using  cadence IC23.1-64b.ISR12.37 , Spectre (R) Circuit Simulator - Version 23.1.0.722.isr15 64bit -- 14 Jan 2025
Using ADE Assembler (maestro view), I run a spectre (+aps) simulation, where I want to limit the number of saved signals to only a particular subcircuit in the hierarchy.  Therefore, from the "Save all..." menu I do the following selections (typing it in because cannot update screeenshot...). On "Basic" tab:
Select signals to output (save) : selected
Select power signals to output (pwr) : none
Select device currents (currents) : selected
Select AC terminal currents (useprobes): no
Subcircuit Probe Level (subcktprobelvl) : empty
Select AHDL variables (saveahdlvars): selected
On "Save by Subckt" tab:
/dut Vdepth = 1
 I get proper netlist creation, at the end of input.scs I read :
iabstol=1e-12 temp=27 tnom=27 scalem=1.0 scale=1.0 compatible=spice2 \
gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 digits=5 cols=80 pivrel=1e-3 \
sensfile="../psf/sens.output" checklimitdest=psf
tran tran stop=200u write="spectre.ic" writefinal="spectre.fc" \
annotate=status maxiters=5
save dut.* sigtype=all depth=1
saveOptions options save=selected pwr=none currents=selected useprobes=no \
saveahdlvars=selected
But when I run the simulation I see in the log that the wildcard expression is not reported at all and all design nets are indeed saved.
Notice from spectre during transient analysis `tran'.
No outputs were found. Loosening output filter criterion to `allpub'.
Opening the PSFXL file ../psf/tran.tran.tran ...
Important parameter values:
start = 0 s
outputstart = 0 s
stop = 200 us
step = 200 ns
maxstep = 4 us
ic = all
useprevic = no
skipdc = no
reltol = 1e-03
abstol(V) = 1 uV
abstol(I) = 1 pA
abstol(Temp) = 100 uC
abstol(Pwr) = 1 nW
temp = 27 C
tnom = 27 C
tempeffects = all
errpreset = moderate
method = traponly
lteratio = 3.5
relref = sigglobal
cmin = 0 F
gmin = 1 pS
Wildcard match summary:
save dut.* : 0
Output and IC/nodeset summary:
save 30 (current)
save 14568 (voltage)
So my question is what am I doing wrong and how can I save all voltages on a specific hierarchical level?
    First thing to check is what the instance line of the "dut" is in the netlist. Is the instance name actually "dut" or does it have other characters before it (e.g. Xdut or Idut)?
  • dtodorov
    dtodorov over 1 year ago in reply to Andrew Beckett
    thanks for the swift response. The instance in the `input.scs` is indeed named "dut" (not Xdut, Idut, etc)
    dut (B FG GND OUT1 OUT2 VDD net06) ab12345cd
    Andrew Beckett over 1 year ago in reply to dtodorov
    I just realised what's wrong - I should have spotted this. You need to specify the depth as 2 not 1, because it's a wildcarded name and it's relative to the top of the design, not within dut. You might also want to change the sigtype on the right side of the Save By Subckt tab to node rather than all, so that it saves voltages and not terminal currents for instances within dut.
  • dtodorov
    that worked! Moving "depth" to 2 seems to have solved it.
    I was misinterpreting the `depth` parameter in the save statement. In documentation it says:
    depth
    Depth of expression matching, i.e. if X:param is a wildcard expression, depth(X:param)=depth(X)=(number of . in X)+1.
    I was expecting a depth to specify the number of levels to save _after_ a match has occurred, which is clearly not the case.
