  3. Unmatched schematic pin label
  • Subscribers 136
  • Views 4105
RV202509139743
RV202509139743 over 1 year ago
I am doing LVS with PVS 241 at the top level of a chip for the tapeout with IO Ring. I have several VDDs (VDDA, VDDB, etc.), all the same voltage. I have 4 "power domains" that are separated by power-cuts. I included one vdd! in the top schematic and a gnd!
One of the errors that I am having is :
Unmatched schematic pin label:
Labeled Schematic Pin | Matched Layout Pin | Matched Layout Net
GND! |                              ** missing pin ** |                 19
vdd! |                                ** missing pin ** |                 43
First, I don't have GND! in schematic, only gnd!.
Second, the layout nets gnd! (net 19) and vdd! (net 43) appear to be correctly connected upon visual inspection, so I'm not sure why the LVS is failing to match them.
BTW I do have a pin on M1, M2, M3, M4, still same error.
Here is an image of LVS output.
https://postimg.cc/yDTBMFJM
Thank you.
  • RobMan
    RobMan over 1 year ago +1
    This is simply that you are missing the pin label in the layout.... Or that is is on the incorrect layer. Also not that you will require lvs_compare_case no if you wish GND! and gnd! to match...…
  • RobMan
    lvs_compare_case no
    if you wish GND! and gnd! to match... but I would recommend changing the label case.
