  3. Maestro ERROR for bus ">" when plot signals
  • Subscribers 136
  • Views 814
LH202509171654
LH202509171654 over 1 year ago
I have write a "save.scs" and include it in model library to plot waves when I did the post-simulation
but there is ERROR when the plotted wave which is BUS signal
the ERROR in log is:
ERROR (SFE-874): "/~~~/save.scs" 22: 24: Unexpected operator ">". Expected end of file or end of line. Cannot run the simulation because of syntax error. Correct the error and rerun the simulation.
for example: when I write: save I11.I12.A, there is no ERROE and can be plotted correctly.
when I write: save I11.I12.A\\<*\\>, will happened ERROR above
the Cadence Version I used is IC23.1-64b.ISR3.27
Is there a way to fix this issue?
