  3. Quantus PVS Parasitic Extraction ERROR (LBRCXM-992)
  • Subscribers 136
  • Views 2696
RV202509139743
RV202509139743 over 1 year ago
I am trying to perform PEX with Quantus based on the guide provided by the foundry and having the following errors (I already did a LVS and it's clean for extraction):
ERROR (LBRCXM-674): File '/home/mr_wolf/work/PvsLVS/inv_top_test/inv_top_test.agf' does not exist or is not readable.
ERROR (LBRCXM-992): Put the file "PEGASUS_FORMAT_VERSION" or "PVS_FORMAT_VERSION" under the path /home/mr_wolf/work/PvsLVS/inv_top_test can solve the crash.
ERROR (LBRCXM-709): ***** Quantus terminated abnormally *****
Quantus version: 24.1
Thank you in advance.
