  3. Problem with ADE Explorer and spectre_encrypt (IC 21.1 ISR22...
  • Subscribers 137
  • Views 4085
Problem with ADE Explorer and spectre_encrypt (IC 21.1 ISR22)
GL202502244954
GL202502244954 over 1 year ago
I’m running ADE Explorer with IC 21.1.0.854 ISR22 and my simulations keep failing. The netlisting phase completes, but when the simulation starts, it crashes with the following error:
free(): invalid pointer
Aborted
spectre_encrypt -all -i .../ade.scs -o .../ade_e.scs
I have observed that:
  • ADE always tries to generate ade_e.scs using spectre_encrypt.
  • In ISR22, spectre_encrypt fails, so the simulation never runs.
  • I don’t see any option in Setup → Environment Options to disable netlist encryption.
  • Running the plain input.scs manually with Spectre doesn't work too
So my questions are:
  • Is there a way to disable netlist encryption in ADE Explorer in IC 21.1 ISR22?
  • Has this spectre_encrypt crash been fixed in a later ISR or IC release?
  • Is there any official Cadence workaround/patch for ISR22?
Thanks in advance!
  • TS202510184222
    TS202510184222 9 months ago
    Did anyone get a solution for this?
    Andrew Beckett 9 months ago in reply to TS202510184222
    The original post was talking about an IC version that doesn't exist - I assume that must have been the Spectre version.
    Can you try this from the UNIX command line:
    spectre +query=sysinfo
    and post what it shows?
