  3. I am not able to select the layer while drawing a wire or...
  • Subscribers 136
  • Views 2783
I am not able to select the layer while drawing a wire or a bus in Layout.
skillEater
skillEater over 1 year ago
I am not able to select the metal layer in LSW in while drawing a wire or a bus.
I reinvoked multiple times but has not worked.
I am drawing the bus and changing the metal later for now.
If somebody knows what could be wrong.
Please help me.
Thank you
Ganesh Dooddipatla.
  • RobMan
    RobMan over 1 year ago
    Hi Ganesh,
    This should work. Does a single wire behave the same way?
    Refering ot "LSW"; Virtuoso now have uses Layer Palette Assistant.Which version of Virtuoso are you using?
    I suggest you contact customer support.
    In the mean time try to remember to preselect the required layer prior to routing.
