  3. ibis2subck for IBIS circuit doesn't extract analogmodel
  • Subscribers 136
  • Views 885
JoseDuarte
JoseDuarte over 1 year ago
Hi ,
I am trying to import an IBIS file into spectre , but it create a netlist that call intances on "analogmode" master cell. Here is an example :
include "analogmodel.scs" section=corner_typ
subckt XXXX_RSW_ibis
    LR_10 ( _10_o 10 ) inductor l=5.71E-10 r=0.017
    C_10 ( 10 0 ) capacitor c=1.28E-13
* instances
    _1 ( _1_o _1_i ) analogmodel modelname=XXXX_IN_DIR_33_typ_XXXX
ends XXXX_RSW_ibis
But this doesnt work because  import fails because is not able to find analogmode master cell.
If I use the -extractmodel option like this :
  • ibis2subckt -in XXX.ibs -out YYY.scs -corner typ  -extractmodel yes
it creates a file with only the models :
* [Model] XXXX_DIR_33
model XXXX_DIR_33_typ_XXXX ibis_buffer type=io polarity=noninv enable=low
+vth=[0.8 2] ccomp=4.59E-12 vrange=3.3
+pulldown=[-4.6 -0.047801 -4.245 -0.045985 -3.88 -0.044045
+    -3.575 -0.042361 -3.235 -0.040408 -2.83 -0.03797 -2.605 -0.036564
+    -2.42 -0.03539 -2.145 -0.03362 -2.005 -0.032686 -1.875 -0.031786
+    -1.65 -0.030141 -1.45 -0.028566 -1.35 -0.027729 -1.26 -0.026942
+    -1.175 -0.026166 -1.095 -0.025401 -1.025 -0.024698 -0.965 -0.024067
+    -0.915 -0.023515 -0.865 -0.022934 -0.8149999999999999 -0.022316 -0.765 -0.021651
+    -0.72 -0.021003 -0.68 -0.020382 -0.655 -0.01997 -0.63 -0.019537
+    -0.605 -0.01908 -0.585 -0.018695 -0.5600000000000001 -0.018185 -0.535 -0.017639
+    -0.51 -0.01705 -0.485 -0.016415 -0.44 -0.015143 -0.41 -0.014211
+    -0.385 -0.013395 -0.34 -0.011872 -0.29 -0.010141 -0.24 -0.0083967
what I am doing wrong on the ibis2subckt commmand to create this analogmodel mastercell?
 best regards
Duarte
