  3. Cannot generate the EMIR report using 'emirreport'
  • Subscribers 136
  • Views 1747
aalbason
aalbason over 1 year ago
Hello all,
I running an EMIR analysis and to the extent of my knowledge I have the proper files and setup needed, but I could be wrong also. I get stumped at the end when the report generation fails.
The error message I get is:
Error found by spectre during transient analysis `tran'.
ERROR (EMIR-1901): Cannot generate the EMIR report using 'emirreport' because the command
'/appl/cadence/mmsim/MMSIM23.10.802/bin/emirreport -mt 8 -64 -c /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/emir.conf -db /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/../psf/input.emir0_bin -log /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/../psf/input.vxfilog -outdir /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/../psf/'
I am not really sure what is causing it since the input.vxfilog has one vague line mentioning an error:
ERROR: Received Segmentation fault signal.
Virtuoso version: IC6.1.8-64b.500.36
MMSIM version: MMSIM23.10.802
Alfonso
  • Saloni Chhabra
    Saloni Chhabra over 1 year ago
    Hi Alfonso,
    Please run emirreport step manually on the command-line. Do you see any errors printed in the terminal? You can copy the exact command from Spectre log.
    emirreport -64 -mt 8 -c ....
    Saloni
  • aalbason
    aalbason over 1 year ago in reply to Saloni Chhabra
    Hi Saloni,
    This is the output from the terminal:
    [al.albason@asl-server al.albason]$ /appl/cadence/ic/06.18.360/bin/emirreport -mt 8 -64 -c /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/emir.conf -db /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/../psf/input.emir0_bin -log /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/../psf/input.vxfilog -outdir /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/../psf/
    /appl/cadence/ic/06.18.360/tools.lnx86/sev/bin/64bit/emirreport
    Log file is /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/../psf/input.vxfilog1
    INFO: Starting Voltus-Fi Batch Mode Application.
    Command run is:
    /appl/cadence/ic/06.18.360/bin/emirreport -mt 8 -c /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/emir.conf -db /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/../psf/input.emir0_bin -log /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/../psf/input.vxfilog -outdir /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/../psf/
    Voltus-Fi version being used is as follows:
    Voltus-Fi batch mode application (64-bit) - High Capacity Power IR/EM - v06.28-s435_1 ((07/23/2024 05:56:01))
    Copyright (c) Cadence Design Systems, Inc. 1996 - 2014
    INFO: Reading file: /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/TO_AIL/QRC/LNR28LPP_QRC_S00-V1.4.2.0_SEC1.4.2.0/LNR28LPP_QRC_S00-V1.4.2.0_SEC1.4.2.0/tcad/7U1x_2T8x_1UTM_LB/nominal/qrcTechFile
    INFO: Reading file: /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/TO_AIL/TECH/LNR28LPP_Voltus_S00-V1.4.5.0/ICT-EM/LNR28LPP_7U1x_2T8x_1UTM_LB.em.ict
    Error checking out license.
    Process Info :
    User time = 0 seconds
    System time = 0 seconds
    Children user time = 0 seconds
    Children sys time = 0 seconds
    Virtual mem. size = 410,812,416 bytes
    Total alloc size = 0 bytes
    In use alloc size = 0 bytes
    Page fault w/o IO = 15,635
    Page fault w/ IO = 65
    No. of swaps = 0
    Page size = 4,096 bytes
    Real Time(HH:MM:SS)= 00:00:00
    Peak Memory Usage = 50712 kB
    INFO: Ending Voltus-Fi Batch Mode Application.
    This is after setting the environment variable:
    setenv CDS_MMSIM_VOLTUSFI_ROOT $CDSHOME
    Per suggestion from Pragati of Cadence support. Referring to the article:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w00000AeQUyEAN
    Using the original command from the Spectre log:
    [al.albason@asl-server al.albason]$ /appl/cadence/mmsim/MMSIM23.10.802/bin/emirreport -mt 8 -64 -c /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/emir.conf -db /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/../psf/input.emir0_bin -log /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/../psf/input.vxfilog -outdir /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/../psf/
    /appl/cadence/mmsim/MMSIM23.10.802/tools.lnx86/sev/bin/64bit/emirreport
    Log file is /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/../psf/input.vxfilog2
    INFO: Starting Voltus-XFi Batch Mode Application.
    Command run is:
    /appl/cadence/mmsim/MMSIM23.10.802/bin/emirreport -mt 8 -c /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/emir.conf -db /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/../psf/input.emir0_bin -log /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/../psf/input.vxfilog -outdir /home/team_proj/workareas/EIC2_LNR28LPP/al.albason/sim_run/tb_clk_skew_cal_diff/spectre/schematic/netlist/../psf/
    Voltus-XFi version being used is as follows:
    Voltus-XFi batch mode application (64-bit) - High Capacity Power IR/EM - v23.10-e282_1 ((01/31/2025 00:25:38))
    Waiting for the checkout of license 'Voltus_XFi_Analysis' ............................................................. ......
    So I take it that the error is caused because of the lack of Voltus_Fi license?
    Alfonso
  • Saloni Chhabra
    Saloni Chhabra over 1 year ago in reply to aalbason
    Hi Alfonso,
    Yes, that's the reason emirreport is erroring out.
    Saloni
