  3. Re: netlisting of verilogA block with choices for prompt...
  • Subscribers 136
  • Views 1653
Re: netlisting of verilogA block with choices for prompt in CDF
SL202411208815
SL202411208815 over 1 year ago
In a verilogA model, I created a parameter call "Configuration" that can take on number of choices such as "Configuration A, Configuration B, Configuration C". The idea is that I can choose between the three choices in Explorer and have different configuration loaded via the verilogA block.
In the Edit CDF window, I selected
name = Configuration
Prompt = Configuration
Type = cyclic
Default Value = "Configuration A"
Store Default = "yes"
Evaluatoin Mode = "Inset"
Choices = "Configuration A,Configuration B,Configuration C"
During netlisting, sometimes the text Configuration="Configuration A" can be split into two lines and appear as Configuration="Configuration \ and the value is not passed to the verilogA block as a parameter. Is there a way to force the netlister to not break the value into two separate lines?
Version of tools is IC23.1
