  3. Is there any way to prevent my definition for model library...
  • Subscribers 136
  • Views 2535
Is there any way to prevent my definition for model library from being overwritten by libInit.il of PDK while virtuoso starts up correctly?
zuiying
zuiying over 1 year ago
Hello! I want to change the defaut model library in ADE L of spectre. Then, I used load("home/IC/my.il").  The my.il is wriiten by me and imports the needed model library. load("home/IC/my.il") indeed works.
Then, I added load("home/IC/my.il") to the end of .cdsinit so that the wanted model library can be imported at the startup of virtuoso. The my.il was loaded successfully at the startup of virtuoso.
My project is based on tsmc PDK. When I open my schematic which uses devices from tsmc, the libInit.il from tsmc pdk will be load automatically. Then, the model library defined in libInit.il will overwrite my definition in my.il.
I have tried ddGetObj() like this:
ddGetObj("TSMC28nm")
These codes are added at the end of .cdsinit.The process library is forced to initialize. The libInit.il from tsmc pdk loaded before my.il successfully. However, the file, tool, and option disappears in CIW, which may mean virtuoso starts up incorrectly.
Is there any way to prevent my.il from being overwritten by libInit.il while virtuoso starts up correctly?
Thank you!
    Andrew Beckett over 1 year ago +1
    Call ciwMenuInit() before the ddGetObj(...) - this should cause the CIW menus to initialise before the libInit.il gets invoked. That is the easiest solution to ensure that your model path customization…
    Call ciwMenuInit() before the ddGetObj(...) - this should cause the CIW menus to initialise before the libInit.il gets invoked. That is the easiest solution to ensure that your model path customization doesn't get overwritten by the PDK.
  • zuiying
    zuiying over 1 year ago in reply to Andrew Beckett
    It works! Really thanks!
