  3. Replace symbol pin names without changing the pin placement...
  • Subscribers 136
  • Views 3259
Replace symbol pin names without changing the pin placement and symbol boundary
SimhanAnalog
SimhanAnalog over 1 year ago
Say I have a symbol with a few pins
o_h<2:0>
o_m
o_a<1:0>
o_b<3:0>
i_c<1:0>
i_d<2:0>
i_f<5:0>
i_g
i_s<3:0>
Say I want to rename the pins as follows retaining the same bit widths
o_b -> o_y
o_a -> o_x
i_d -> i_z
I want to ensure that the symbol dimensions and pin placements remain same so that the schematic where this symbol is instantiated and connections are made is intact.
I will like to provide this pin changes in a text file like below
o_b, o_y
o_a, o_x
i_d, i_z
Is there a simple way to do this? Or does cadence already has some api that can do this?
  • SimhanAnalog
    Any help on this?
    Andrew Beckett over 1 year ago in reply to SimhanAnalog
    You'd need to write some SKILL code to do this. I don't know of anything that does this, although maybe this will help as a starting point: SKILL: How to change a given pin name in a symbol / schematic ? (I haven't looked to see how good that code is - it's quite old).
  • SimhanAnalog
    SimhanAnalog over 1 year ago in reply to Andrew Beckett
    Thanks. I was able to get something working using
    loop across all terminals in symbol
    if terminal needs to be replaced(part of the old port column in csv) do the following
    term~>name = new_name
    But I get the following warning for which I just need to open the symbol and click check and save and it goes away. This warning I get only for the last port on my list.
    Warning: Port "last_new_port<4:0>" in "cell_name symbol" not specified in the portOrder property.
    Warning: Port "last_old_port<4:0>" in the portOrder property not found in "cell_name  symbol".
    Is there a skill way to do it.
    I tried
    schVIC(cv)
    dbSave(cv)
    But it doesn't help(maybe these commands are old). It goes away if I manually open symbol view and click check and save.
  • SimhanAnalog
    SimhanAnalog over 1 year ago in reply to SimhanAnalog
    I got it working by adding
    hiEnqueueCmd("hiDBoxUser(schReplaceOrModifyDialog nil 2)")
    schViewToView(lib_name_d module_name lib_name_d module_name "systemVerilog" "symbol" "_vmsSVVmsToPinList" "schPinListToSymbolGen")
    and again doing
    schVIC(cv)
    dbSave(cv)
