  3. Virtuoso and Allegro Compatibility
  • Subscribers 136
  • Views 2105
forXTer
forXTer over 1 year ago
Is there any official method for simulating a PCB designed in Allegro with an IC designed in virtuoso? The best I have found were some 15+ year old posts that say to export from Allergo with EDIF200 and import into virtuoso. This method seems quite cumbersome with no way for quick iterations.
  • Saloni Chhabra
    Saloni Chhabra over 1 year ago
    Yes, this is possible and the flow is called Virtuoso Heterogeneous Integration. You can read more about it here:
    Here's a working example which demonstrates importing data from Allegro and a roundtrip flow between Virtuoso and Allegro:
    IC25.1: Virtuoso Heterogeneous Integration: Multitechnology Flow Enablement for IC Package and Board
    Please contact Cadence Customer Support if you need more details about this flow.
    Saloni
