  3. Stop Condition of Liberate trio in characterizing a DFF
  • Subscribers 136
  • Views 2148
TN202507027633
TN202507027633 over 1 year ago
Hi all,
Currently i am characterizing setup time of a DFF, and i have a question regarding the stop condition of Liberate trio.
- Testbench :
 The criteria for setup time is degradation and i sweep variable "constraint_delay_degrade" from 0.1 to 1 with the step of 0.1 to observe the setup time reported by the tool. (I purposely set the variable "constraint_delay_degrade_abstol " small  such that it cannot impact the criteria)
- Result :
 There are many cases that i think Liberate stops "too early".
 For instance :
 When "constraint_delay_degrade" is 0.9, the setup time is 17.64ps and ck2q is 4.26ps. The relative difference percentage of this ck2q compared to "relaxed" ck2q is only about 62.6%, which is much less than 90%.
 Furthermore, in the case when "constraint_delay_degrade" is 0.8, the relative difference percentage is higher than the case of 0.9 and equal to 77.8%. (I expect that the 0.9 case should give a higher value of ck2q or relative difference percentage than the 0.8 case)
- Question :
 So my question is, what is the criteria for Liberate to stop searching ? I read in the Liberate manual that it will stop when the number of iteration or simulation time exceeds specified value, but none of these cases is likely to happen in my testbench. The manual also mentions about Brent's algorithm, but i cannot find more information about this in the manual. Therefore, i think it would be great if i can know more about this topic. Please give me any hints for this one.
Thanks for your support
  • Guangjun Cao
    Guangjun Cao over 1 year ago
    With delay pushout as the method, Liberate will stop searching when the clk2q delay increases by the percentage defined by constraint_delay_degrade. The last two simulations will check by slightly varying the clk/d timing and ensure changes in clk2q delay is with constraint_delay_degrade_abstol. then one of the last two clk/D timing is used in .lib.
    Before doing bisectional search, tool will check if the defined vector is valid. This typically is done within the first 3-5 simulations. During this phase, D edge is wither well before (for setup) or after (hold) clk. clk2q delay is measure at such points and used as the reference. Next, during the bisection search, each time, clk/d timing is varied, clk2q delay is measured and compared to the reference. once constraint_delay_degrade(defalt is 10% of reference) is reached, tool will refine the steps until adjecent simulations do not show changes more than  constraint_delay_degrade_abstol(2ps by default).
    Hope this is helpful.
    Guangjun
