  3. Assembler: possible to force inclusion of model file(s)...
  • Subscribers 136
  • Views 1696
Assembler: possible to force inclusion of model file(s) at the very beginning of netlist?
dontpanic
dontpanic over 1 year ago
Is it possible to force the order in which "model" (.scs) files are included in the netlists that Assembler produces? For example, force it to add them right at the beginning of the netlist (just like it somehow always does for "ade_e.scs")?
Context: I have some big testbenches in which some variables are defined by means of .scs files, which are then included as model files in Assembler. This works great, except that then it becomes impossible to sweep these variables through corner definitions (as I normally could for any explicitly-defined variable in Assembler), because the values Assembler assigns at each sweep point get overridden in the netlist by the hardcoded definitions in those model files.
The above could be avoided if the model file were included *earlier* in the produced netlists, as then it would be the hardcoded values the ones to get overriden by the local values assigned by Assembler at each sweep point, instead of the opposite. Is there any way to achieve this effect?
Thanks in advance for any help!
Jorge.
  • Saloni Chhabra
    Saloni Chhabra over 1 year ago +1
    Hi Jorge, Yes, this is possible by adding this setting to .cdsinit: envSetVal("spectre.envOpts" "netlistModelFileFirst" 'boolean t) This will move the model statements before 'parameters' statement…
  • Saloni Chhabra
    Hi Jorge,
    This will move the model statements before 'parameters' statement so the swept value will take effect.
    include "./param.scs"
    parameters temperature=27 CTRL=10
    Saloni
  • dontpanic
    dontpanic over 1 year ago in reply to Saloni Chhabra
    Thanks so much for your suggestion; Saloni! I tried it and while the model files are now being included at the top of the netlists, the simulations now fail because for some reason Assembler is including a few empty parameter definitions in the netlist for some of the variables being defined in the model files.
    So, for example, now I see in my netlist something like this:
    [...usual input.scs header stuff...]
    include "/path/to/my_model_file1.scs"
    include "/path/to/my_model_file2.scs"
    include "path/to/some/other_model_file.scs"
    parameters parameterA parameterB parameterC \
        parameterD parameterE parameterF \
    parameter1=value1 parameter2=value2 parameter3=value3 \
       parameter4=value4 parameter5=value5 \
       parameter99=value99 \
    [...rest of netlist as usual...]
    where "parameterA-F" are some of the parameters being defined in my model files, while "parameters1-99" are other parameters with explicit definitions in the Assembler view (they are Global Variables).
    Thus, since "parameterA-F" are being explicitly included in the netlist but without a value, the simulation is fails.
    I noticed that if I remove those empty parameter definitions from the nestlist, then everything works as expected, and I am able to get the desired behavior (this however is not a practical solution, as I need to run hundreds of simulations).
    ...Any ideas on how I could prevent those spurious, empty inclusions for the variables being implicitly defined in the model files?
    KR, Jorge.
    Andrew Beckett over 1 year ago in reply to dontpanic
    Jorge,
    When something wasn't quite right (perhaps as you were trying to get this sorted out), ADE can add parameters that are encountered in a simulation that weren't defined - are they showing up now as design variables in the test (the parameterA-F parameters, that is?). If so, try deleting them in ADE and trying again - hopefully they will be found from your model files and then not added back in ADE.
