  3. PSS + PSTB for Buck converter
  • Replies 17
  • Subscribers 140
  • Views 7430
TH202510293247
TH202510293247 over 1 year ago
I am new to power converters. I am currently working on a controller design for buck. I wanted to simulate the stability response for the circuit. While pss is working as per expectation, pstb is giving '0' (-6.4kdB) loop gain and phase. I am using voltage source as probe at the o/p to break the circuit. Can anyone help me - what i am missing here?
  • Frank Wiedmann
    Frank Wiedmann over 1 year ago in reply to TH202510293247
    I suggest that you take a look at https://designers-guide.org/forum/YaBB.pl?num=1189658426 and check if (too) ideal components in your circuit are causing this effect. Please also note Ken's remark at https://designers-guide.org/forum/YaBB.pl?num=1107716368/53#53 : "To get PAC to work on a behavioral comparator model you need a transition region where the gain is finite, and the PSS analysis must put some points down in that region." Of course, this also applies to PSTB and PXF.
  • TH202510293247
    TH202510293247 over 1 year ago in reply to Frank Wiedmann
    Thanks Frank.. Understood the issue.
    I guess simplis supports analysis period op. point analysis (pop) and (p)ac for these type of circuits.
    Is there any hack I can use in cadence to get the results similar to simplis?
  • Frank Wiedmann
    According to my experience, PAC, PXF and PSTB usually work very well if the circuit is built with real devices (transistors etc.) and does not use ideal components or Verilog-A models. If you want to use such ideal components, you need to make sure that the conditions I mentioned above are satisfied.
  • NK202510274558
    NK202510274558 over 1 year ago in reply to TH202510293247
    Out of curiosity I tried this out. For some reason I am unable to attach images to this post. They are at this link.
    The gain from dc to dc (0th harmonic conversion) should be 0.5. But it is all over the place The results depend slightly on the number of harmonics, but doesn’t make much difference.
    Bottomline: Greed is bad! Limiting yourself to a total gain of ~ 100 is OK.
    Nagendra
  • Frank Wiedmann
    Frank Wiedmann 11 months ago in reply to NK202510274558
    Did you check how well the condition mentioned above is satisfied?
    How many points did you get in the transition region for the different values of Gcomp? You can find this out by double-clicking on the trace in ViVA and selecting both "Turn On Symbols" and "Show All Points".
  • NK202510274558
    NK202510274558 11 months ago in reply to Frank Wiedmann
    Got the time to look at this only now. For Gcomp=100, there are a few points (4-6), for Gcomp=1000, only one.
    I had thought that the small-signal equivalents for controlled sources (including limiting) would be hardcoded correctly from the linear picture. But I guess they are calculated from the simulated points.
    Nagendra
  • Frank Wiedmann
    Your guess is correct ;-)
    One possible way to increase the number of simulated points is to increase the value of the maxacfreq parameter of the pss analysis.
