  3. Assembler: possible to disable automatic evaluation of output...
  • Subscribers 136
  • Views 1934
Assembler: possible to disable automatic evaluation of output expressions?
dontpanic
dontpanic over 1 year ago
Hi! Is it possible to disable the automatic evaluation of output expressions, so that they are only evaluated when pressing the "re-evaluate outputs" button?
Context:
When simulating sweeps I often face the situation where some output expressions fail to evaluate when Assembler tries to automatically evaluate them, but evaluate correctly when I use the "re-evaluate outputs" button once all the sweep simulations are finished (usually this happens when I have ocean and/or Matlab outputs defined in those tests, so I always assumed it had to do with some causality issues that vanish when all the points are done simulating).
The problem is that now I have some tests with very heavy post-processing outputs, and when running long sweeps the automatic evaluation of those outputs takes significant CPU resources, to the point that it interferes with the actual simulations, which then take unnecessarily longer to finish. And, what is worse, it's all useless because the actual outputs still fail to evaluate because of the aforementioned causality issue. So I anyway need to re-evaluate everything once the sweeps are done.
Thus, I would like to disable the automatic evaluation of all outputs, so that they are only evaluated when I manually press the "re-evaluate outputs" button, once all simulations are finished.
Is there a way to achieve this effect?
Thanks in advance for any help!
KR, Jorge.
    Jorge,
    Well, this shouldn't be necessary - it suggests that either something is wrong with the setup of these expressions (hard to identify without seeing them) or there's a bug in the software.
    The only way that I can think of to achieve your goal is to disable the "plot" for these expressions when running the simulations, and then to re-enable the "plot" checkbox and hit the re-evaluate button. That's clunky, and the best solution would be to find out what's really going on - the best would be via customer support (then we can take a look).
