  3. copy of a maestro view and chnaging design cause all the...
  • Replies 14
  • Subscribers 139
  • Views 12452
copy of a maestro view and chnaging design cause all the setup to be lost
TommasoF
TommasoF over 1 year ago
Hi all,
IC23.1 ISR16 / ISR15.
when making a copy of a maestro view and then in the new maestro view I change the design schematic (see below) , I loose all the ADE outputs and the analysis. Is there any fix to this bug ? it was not happening in the IC618
thanks
  • mxgong
    mxgong 7 months ago in reply to Andrew Beckett +1
    Hi Andrew, Any update on this? If I accidently changed the design of the test, how to restore the settings and outputs? Are these data simply removed or there is any name bug in the active.state file…
    Andrew Beckett over 1 year ago in reply to TommasoF
    I didn't see this reply (I'm having some issues with not all posts generating a notification). Anyway, the only way I can get this to misbehave is to leave the Mode as "AutoScale" and then use toggle the little arrow next to Axis Limits down and up so I can edit the min and max fields, and then apply - if I do that it discards the change because it's still auto-scaling (in my view it shouldn't really allow them to be editable in this case). Otherwise it seems to work fine.
    There have been fixes during IC23.1 to the axis editing (to fix other earlier bugs); I guess it is possible that in some situation it's broken something else - but I am a bit surprised that the basic changes you are describing here are not working.
  • DY202512044834
    DY202512044834 11 months ago in reply to RP202511066849
    Could you provide a more detailed explanation of the parameters or setup when using the copy wizard? I recently encountered this problem as well.
    Andrew Beckett 11 months ago in reply to DY202512044834
    The important part is as I describe it above here.
  • mxgong
    Any update on this?
    If I accidently changed the design of the test, how to restore the settings and outputs? Are these data simply removed or there is any name bug in the active.state file that we could manually change it to restore?
    thanks,
    Minxiang
