  3. skill debugging in CIW (6.1.7)
  • Subscribers 136
  • Views 1987
JJ202502261359
JJ202502261359 11 months ago
<test.il file>
procedure(test()
let((a)
  a = 1
  a += 1
  a += 10
  a += 100
  for(i 1 10 printf(">>> %d\n" i)
i want to debug test.il with CIW commands (like GDB for C), not with skillide.
so i tried the following commands:
load("test.il")
installDebugger()
;; (1) Set a breakpoint on the 3rd line of test.il
test()
dump()
next()
;; (2) Find out which *.il file and which line is currently being executed
debugQuit()
uninstallDebugger()
in the above process i would like to know how to execute steps (1) and (2).
when i run debugStatus() for step(2), all the fields in the returned data are nil.
    Andrew Beckett 11 months ago
    There's no public function to set line breakpoints. Similarly, there is no function that I can see to retrieve the current file and line (the debugger knows, but I don't think it's exposed as a SKILL function, even a private one).
