  3. Register Host ID
  • Subscribers 136
  • Views 2100
Register Host ID
SM202508046750
SM202508046750 11 months ago
Sir,
I have register on Cadence Portal.
Trying to Register Host ID.
But not able to Find Register Option.
While Trying to open  https://support.cadence.com  portal it again ask for host id.
Please help me to complete procedure
    Andrew Beckett 11 months ago
    The hostid is the host id of the license server. Usually easiest to ask your CAD as they would know this, but simply you can look at the value of the $CDS_LIC_FILE env var (or failing that $LM_LICENSE_FILE) and this will usually be something like 5280@somehostname (it might be a file name). If it's a hostname, log onto that host (e.g. ssh somehostname) and then run "lmhostid" to find out the host id. Or identify the license file on that machine and look at the SERVER line at the top to see the hostid code.
    Failing that, email support@cadence.com and ask for help in setting up your login.
