  3. Offset Parameters in Instance Array
  • Subscribers 136
  • Views 1808
AR202511272845
AR202511272845 11 months ago
How can one set different offset values for parameters in an instance array. For example, I want to make a vdc, V1<n:0>, with values on the bus lines equal to 0*offset,1*offset,2*offset,3*offset,...,n*offset.
How would I get this feature without having to instantiate n different sources.
    Andrew Beckett 11 months ago
    There's no built-in way of doing this - you can't have different parameter values on members of an iterated instance.
    However, I just created a symbol/schematic PCell to achieve the same goal. This code creates a component in a library of your choice (by default called "vdcbus") which has a parameter to control the bus width, and also a DC voltage and an offset per bit.
    /* abCreateVdcbus.il
    Author     A.D.Beckett
    Group      Custom IC, Cadence Design Systems Ltd.
    Date       Nov 29, 2025
    Modified
    By
    Create a component that has a variable width bus output, and within
    creates an instance of vdc for each bit, which has vdc+n*offset as the
    voltage of that bit.
    Usage: abCreateVdcbus("mylib") or abCreateVdcbus("mylib" "vdcoffset")
    SCCS Info: @(#) abCreateVdcbus.il 11/29/25.13:35:32 1.1
    procedure(abCreateVdcbus(library @optional (cell "vdcbus"))
     let( (pcellId)
        unless(ddGetObj(library)
            error("Couldn't open library %L" library)
        ; First the schematic. Note that the schematic only has the instances
        ; and logical connectivity (nets, terminals, instTerms) - no wires or
        ; pins. Don't really need to be able to probe within the schematic
        ; so make life easier by not constructing all the geometries!
        pcellId=pcDefinePCell(
            list(ddGetObj(library) cell "schematic" "schematic")
            ; Formal parameters
                (buswidth 6)
            ; Code itself
            let(( cv master vdcInst bitNet plusNet minusNet)
            cv = pcCellView
            ; Convert parameters
            when(buswidth<1 buswidth=1)
            ; create the nets and terminals
            minusNet=dbMakeNet(cv "MINUS")
            plusNet=dbMakeNet(cv sprintf(nil "PLUS<%d:0>" buswidth-1))
            dbCreateTerm(minusNet minusNet~>name "inputOutput")
            dbCreateTerm(plusNet plusNet~>name "inputOutput")
            ; create the instances of vdc
            master = dbOpenCellViewByType( "analogLib" "vdc" "symbol" nil "r" )
            for(bit 0 buswidth-1
                vdcInst =
                    dbCreateInst(
                        cv master sprintf(nil "VDC%d" bit)
                        0:bit*0.8 "R0"
                ; Create the properties on each instance
                vdcInst~>vdc=lsprintf("pPar(\"vdc\")+pPar(\"offset\")*%d" bit)
                ; Connect it up
                bitNet=dbMakeNet(cv lsprintf("PLUS<%d>" bit))
                dbCreateConnByName(minusNet vdcInst "MINUS");
                dbCreateConnByName(bitNet vdcInst "PLUS");
            ) ; for
            ; Make the connectivity look up to date - shouldn't really be needed!
            dbSetConnCurrent(cv)
            dbClose( master )
            t
        dbSave(pcellId)
        dbClose(pcellId)
        ; Now the symbol. This reuses the analogLib/vdc/symbol as a template
        ; but changes the PLUS pin to be a bus
            list(ddGetObj(library) cell "symbol" "schematicSymbol")
            ; Formal parameters
                (buswidth 6)
            ; Code itself
            let(( cv template inst plusTerm plusFigs plusNet)
            cv = pcCellView
            template = dbOpenCellViewByType("analogLib" "vdc" "symbol")
            inst=dbCreateInst(cv template "" 0:0 "R0")
            ; shapes on instance layer are not preserved during flatten
            foreach(lpp inst~>master~>lpps
                when(lpp~>layerName=="instance"
                    foreach(shape lpp~>shapes
                        dbCopyFig(shape cv)
            dbFlattenInst(inst 1 t t nil nil t t)
            ; Remove existing PLUS pin and reuse the figures for
            ; a new PLUS<x:0> pin
            plusTerm=dbFindTermByName(cv "PLUS")
            plusFigs=car(plusTerm~>pins)~>figs
            plusNet=plusTerm~>net
            dbDeleteObject(plusTerm)
            dbDeleteObject(plusNet)
            plusNet=dbMakeNet(cv lsprintf("PLUS<%d:0>" buswidth-1))
            plusTerm=dbCreateTerm(plusNet plusNet~>name "inputOutput")
            foreach(fig plusFigs
                dbAddFigToNet(fig plusNet)
            dbCreatePin(plusNet car(plusFigs) "" plusTerm)
            ; Correct the cdsTerm label
            foreach(shape cv~>shapes
                when(shape~>objType=="label" && shape~>theLabel=="cdsTerm(\"PLUS\")"
                    shape~>theLabel=lsprintf("cdsTerm(\"%s\")" plusNet~>name)
            t
        dbSave(pcellId)
        dbClose(pcellId)
        ; Now create the CDF
        let( (cellId cdfId )
            unless( cellId = ddGetObj( library cell )
                error( "Could not get cell %s." cell )
            when( cdfId = cdfGetBaseCellCDF( cellId )
                cdfDeleteCDF( cdfId )
            cdfId  = cdfCreateBaseCellCDF( cellId )
            ;;; Parameters
            cdfCreateParam( cdfId
                ?name           "buswidth"
                ?prompt         "Bus Width"
                ?defValue       6
                ?type           "int"
                ?display        "t"
                ?name           "vdc"
                ?prompt         "DC Voltage"
                ?defValue       "0"
                ?type           "string"
                ?parseAsCEL     "yes"
                ?parseAsNumber  "yes"
                ?display        "t"
                ?name           "offset"
                ?prompt         "Offset Per Bit"
                ?defValue       "0"
                ?type           "string"
                ?parseAsCEL     "yes"
                ?display        "t"
            ;;; Simulator Information
            cdfId->simInfo = list( nil )
            cdfId->simInfo->UltraSim = '( nil )
            cdfId->simInfo->auCdl = '( nil )
            cdfId->simInfo->auLvs = '( nil )
            cdfId->simInfo->cdsSpice = '( nil )
            cdfId->simInfo->hspiceD = '( nil )
            cdfId->simInfo->spectre = '( nil )
            ;;; Properties
            cdfId->formInitProc            = ""
            cdfId->doneProc                = ""
            cdfId->buttonFieldWidth        = 340
            cdfId->fieldHeight             = 35
            cdfId->fieldWidth              = 350
            cdfId->promptWidth             = 175
            cdfId->paramLabelSet           = "buswidth vdc offset"
            cdfId->paramDisplayMode        = "parameter"
            cdfId->paramEvaluate           = "t nil nil nil nil"
            cdfSaveCDF( cdfId )
