  3. How to run multiple analysis (ac, stb) in Monte-Carlo s...
  • Subscribers 136
  • Views 2106
How to run multiple analysis (ac, stb) in Monte-Carlo simulation
AdrienL
AdrienL 11 months ago
This is an up of this question :  How to run multiple analysis (ac, stb) in one test and make it work in Monte-Carlo simulation
Because I am in the same situation, everything works in sweep, but I don't have the results in the results browser in MonteCarlo.
I'm thinking it might be due to some saving parameters ?
  • AdrienL
    AdrienL 11 months ago +1
    For the future readers, the Cadence support helped me and found me a perfectly working solution. However, I can't share the solution here, so I recommend to reach the support directly. A CCR should be…
  • AdrienL
    I think it's also related to this :  Using text files to define spectre analysis with monteCarlo
    I don't know if anything came up since ?
    Andrew Beckett 11 months ago in reply to AdrienL
    The issue is that any analysis included via a model file or definition file will be outside of the Monte Carlo analysis.
    As advised in that post, I suggest you contact customer support about this (use the case menu to submit a support case) and have the AE who picks it up contact me and I can suggest the "early access" way of doing this (I can't advertise it, because for various reasons we've not enabled this by default; we would however then be able to add you as another customer who needs this as a stopgap until full support for multiple analyses of the same type is added).
  • AdrienL
    AdrienL 11 months ago in reply to Andrew Beckett
    Hello, thank you for your reply.
    I'd be very happy to be one of the "beta tester". I created a case, I hope I'll have the access!
  • AdrienL
    For the future readers, the Cadence support helped me and found me a perfectly working solution. However, I can't share the solution here, so I recommend to reach the support directly. A CCR should be opened, thus the solution should become public some day.
