  3. I cannot open maestro or adexl views (IC 6.1.8)
  • Subscribers 136
  • Views 2274
MA202408239313
MA202408239313 11 months ago
My virtuoso locks for while (sometimes crashing) every time I try to open/create maestro or adexl views. ADE-L is working normally.
When it doesn't just crash, I get the following output at the CIW:
axlBeanstalkd process '29946' was stopped, the last strace information before it's stopped is dumped to '/tmp/strace_2025_12_03_13_42_48_29946'
Messages already created for current virtuoso session was lost and cannot be recovered.
*Error* error: Timed out attempting to connect to launched beanstalkd process. - nil
<<< Stack Trace >>>
(... in axlSetMainSetupDB ...)
(... in _axlInitSessionWindow ...)
(... in _axlSetupSession ...)
(... in _axlDataTrigger ...)
(... in _deApplyTrigger ...)
(... in unknown ...)
funobj@0x2a561188()
(... in _dePullTrigger ...)
(... in _deCallDataTrigger ...)
(... in _deOpenLevel ...)
(... in _deOpen ...)
(... in deOpen ...)
deOpen()
*WARNING* (DEBASE-102079): A SKILL error occurred in function _axlDataTrigger
*WARNING* (DEBASE-102084): Data trigger for viewType maestro failed.
looking at /tmp/strace_2025_12_03_13_42_48_29946, I just get the redundant information:
[max@opa lp_working_dir]$ more /tmp/strace_2025_12_03_13_42_48_29946
strace: attach: ptrace(PTRACE_SEIZE, 29946): No such process
When virtuoso is invoked, the only exhibited warning is:
*WARNING* Connection to opa.ece.ttu.edu failed. No route to host
My checkSysConf returns the following results:
[max@opa lp_working_dir]$ /home/cdsmgr/cadence/installs/IC618/tools/bin/checkSysConf IC6.1.8
[Copyright 2002-2022] Cadence Design Systems, Inc. All rights reserved.
This program and online documentation may not be copied, modified,
re-published, uploaded, executed, or distributed in any way, in any
medium, whether in whole or in part, without prior written permission
from Cadence Design Systems, Inc.
============== checkSysConf: Version 3.51 ====================
Date information gathered: Wed Dec 3 14:43:34 CST 2025
Host Name ..............: opa.ece.ttu.edu
Hostid .................: 830a1911
Operating System .......: Linux / x86_64
OS Version .............: Red Hat Enterprise Linux Server release 7.9 (Maipo)
Kernel Version .........: 3.10.0-1160.80.1.el7.x86_64
Hardware Type ..........: x86_64
Memory .................: 31723 Megabyte
CPU model ..............: Intel(R) Xeon(R) W-2275 CPU @ 3.30GHz
No. of CPUs ............: 28
Total Swap Space........: 16000 Megabyte
X Server ...............:
Patch Data file ........: /home/cdsmgr/cadence/installs/IC618/share/patchData/Linux/x86_64/redhat/7.0WS/IC6.1.8
**************** Now verifying configuration ****************
Validating Kernel requirements...
Minimum Installed Status Info
3.10.0-514 3.10.0-1160.80.1.el7.x86_64 PASS
Validating MEMORY requirements MegaByte ...
4096MB 31723MB PASS
Validating SWAP requirements in MegaByte ...
4096MB 16000MB PASS
Validating DISPLAY requirements...
8 planes 32 planes PASS
PseudoColor DirectColor
Validating XKEYBOARD extension requirement...
Requirement Installed Status Info
Required Yes PASS
Validating PACKAGE requirements.....22 to check
# PACKAGE Release Build Installed Arch Status Info
1 glibc 2.17 157 2.17-326.el7_9.3 x86_64 PASS
-> 'GlibC'
2 elfutils-libelf 0.166 2 0.176-5.el7 x86_64 PASS
-> 'Libelf Library'
3 ksh 20120801 26 20120801-144.el7_9 x86_64 PASS
-> 'ksh'
4 mesa-libGL 11.2.2 2.20160614 18.3.4-12.el7_9 x86_64 PASS
-> 'Mesa libGL Library'
5 mesa-libGLU 9.0.0 4 9.0.0-4.el7 x86_64 PASS
-> 'Mesa libGLU Library'
6 motif 2.3.4 8 2.3.4-14.el7_5 x86_64 PASS
-> 'Openmotif'
7 libXp 1.0.2 2.1 1.0.2-2.1.el7 x86_64 PASS
-> 'libXp'
8 libpng 1.5.13 7 1.5.13-8.el7 x86_64 PASS
-> 'libpng'
9 libjpeg-turbo 1.2.90 5 1.2.90-8.el7 x86_64 PASS
-> 'libjpeg'
10 expat 2.1.0 8 2.1.0-15.el7_9 x86_64 PASS
-> 'libexpat.so.0'
11 glibc-devel 2.17 157 2.17-326.el7_9.3 x86_64 PASS
-> 'GlibC-devel'
12 gdb 7.6.1 64.el7 7.6.1-120.el7 x86_64 PASS
-> 'GNU debugger'
13 xorg-x11-fonts-misc 7.5 9 7.5-9.el7 noarch PASS
-> 'Fonts'
14 xorg-x11-fonts-ISO8859-1-75dpi7.5 9 7.5-9.el7 noarch PASS
-> 'Courier 12pt font'
15 redhat-lsb 4.1 27 4.1-27.el7 x86_64 PASS
-> 'lsb'
16 libXScrnSaver 1.2.2 6.1.el7 1.2.2-6.1.el7 x86_64 PASS
-> 'libXScrnSaver'
17 apr 1.4.8 3 1.4.8-7.el7 x86_64 PASS
-> 'APR library 64 bits'
18 apr-util 1.5.2 6 1.5.2-6.el7 x86_64 PASS
-> 'APR Utility library 64 bits'
19 compat-db47 4.7.25 27 4.7.25-28.el7 x86_64 PASS
-> 'libdb-4.7'
20 xorg-x11-server-Xvfb 1.15.0 32 1.20.4-29.el7_9 x86_64 PASS
-> 'Xvfb'
21 mesa-dri-drivers 17.2.3 8.20171019 18.3.4-12.el7_9 x86_64 PASS
-> 'Mesa drivers'
22 openssl-devel 1.0.1e 60 1.0.2k-25.el7_9 x86_64 PASS
-> 'OpenSSL library'
Validating WRITABLE-FILE .....1 to check
# WRITABLE-FILE Exists Status Info
1 /dev/shm YES PASS edpSharedMemory
Normal exit. This workstation (opa.ece.ttu.edu) status is: PASS
Host opa.ece.ttu.edu has a Cadence supported Linux configuration.
Exiting checkSysConf ... Good-bye
Output is saved as /tmp/checkSysConf.opa.ece.ttu.edu-2025.12.03.14:43.56646.log
My Virtuoso and Spectre versions are the following:
[max@opa lp_working_dir]$ virtuoso -W
sub-version IC6.1.8-64b.500.36
[max@opa lp_working_dir]$ spectre -W
sub-version 20.1.0.434.isr14
Could you please share your thoughts for a possible solution?
If you need further information, please let me know.
Best regards,
Max
