  3. Need help on creating vias with bindkey in IC23.1
  • Subscribers 136
  • Views 2088
JanD315
JanD315 11 months ago
Hi I used this bk("Layout" "<Key>t" "le0ViaForm->viaMode->value= \"Single\" le0ViaForm->viaSingleModeScrollView->viaDefName->value = \"M2_M1\" leHiCreateVia()") to create via1 in older Virtuoso, it worked well. However, when I use IC23.1, the bindkey opens the "Create Form" GUI before creating a via. And the GUI always use my last choice of vias by default.
Then I write this code to force the form not open. This script works, but the via can only be moved post-drop. I can't pick a point then drop it. Can anyone help me with it? Also, I need help to make a bindkey for stacked via and auto via. Thanks!
defun(placeViaAndDrag (viaName @key (orient "R0") (params nil))
let((win cv tf viaDef pt inst)
win = hiGetCurrentWindow()
cv = geGetEditCellView()
unless(win && cv
error("No active layout window/cellView."))
tf = techGetTechFile(cv)
viaDef = techFindViaDefByName(tf viaName)
unless(viaDef
error(sprintf(nil "ViaDef '%s' not found." viaName)))
pt = geWindowToEditPoint(win hiGetPoint(win))
inst = dbCreateVia(cv viaDef pt orient params)
when(inst
geDeselectAll()
geSelectFig(inst)
leHiMove()
printf("Created via: %L\n" inst)
inst
); let
); defun
hiSetBindKey("Layout" "<Key>t" "placeViaAndDrag(\"M2_M1\")")
    Andrew Beckett 11 months ago
    The form also appears for me in IC6.1.8.
    This code hopefully does what you want:
    procedure(CCFinitViaForm(viaMode viaDefName @optional keepForm)
      let((viaForm)
        viaForm=leGetTechFormList(techGetTechFile(geGetEditCellView()))->viaForm
        viaForm->viaMode->value=viaMode
        viaForm->viaSingleModeScrollView->viaDefName->value=viaDefName
        when(!keepForm && hiIsFormDisplayed(viaForm)
          hiToggleEnterForm()
    procedure(CCFcreateVia(viaMode viaDefName)
      ; Delay completing the form until it's been created and displayed.
      ; This also hides the form after initial display
      hiEnqueueCmd(
        lsprintf("CCFinitViaForm(%L %L)" viaMode viaDefName)
      leHiCreateVia()
    hiSetBindKey("Layout" "<Key>t" "CCFcreateVia(\"Single\" \"M2_M1\")")
  • JanD315
    JanD315 11 months ago in reply to Andrew Beckett
    Hi Andrew, it worked. Thank you so much for your help.
