  3. Net Tracer Not working properly in virtuoso IC23.1 -Need...
  • Subscribers 136
  • Views 727
Net Tracer Not working properly in virtuoso IC23.1 -Need Help
HH202512086128
HH202512086128 11 months ago
-I am working on a skill where I am using the Net tracer function to find the over-lap of the metal's which does not contain the respective via's.
-Script worked fine but after 4-5 runs Net tracer is not working properly
-ERROR: error in routine put prop message : first arg must be either symbol , list , def , struct or user type for net
    Andrew Beckett 11 months ago
    This isn't really enough information; the error message is a fairly generic SKILL error that could be all sorts of things - and the issue might be in your code, or might be in the net tracer itself. Without seeing the code it's hard to be sure. If you set:
    _stacktrace=50
    then it would give some detail as to what's triggering the error when it occurs - but you would need to provide the code to get any further advice. If you can't do that here, I suggest you contact customer support (use the Case menu to submit a support case after logging in).
    Kind Regards,
