  3. Virtuoso (IC25.1) startup very slow (~5mins) after Linux...
  • Subscribers 136
  • Views 3002
Virtuoso (IC25.1) startup very slow (~5mins) after Linux Update
mahodk
mahodk 10 months ago
I recently updated my Linux workstation to Alma Linux 9.7 from openSUSE Leap  15, since that platform is not supported by Cadence.
In openSUSE I had Virtuoso starting in less than 30 seconds, in my new setup it takes over 5 mins and when I open the library manager it is another ~ 5 mins.
There are no undefined or missing libraries in my Library Manager.
In my new installation the checkSysConf is PASS. The CDS.log from invoking virtuoso shows it takes almost 400s.
I tried invoking libManager by itself and it reports the following warnings, which I have not been able to find any info on:
\w Warning: Mps Error: "_mpsReadOrGet:could not connect with cdsMsgServer on host mxcserver
\w "
\w Warning: Mps Error: "mpsRegInterest:could not connect with cdsMsgServer on host mxcserver
Finally I also see this message in dashboard_CDS.log: "*WARNING* Failed to connect to mxcserver 6870"
I am thinking there is a port, permission or network setup which is set incorrectly in the new Linux install.
Looking for any hint or help on how to resolve this. I was unable to attach tiles, but have them available.
Thanks for your help
    Andrew Beckett 10 months ago
    I didn't see the original post (occasionally something goes wrong with the email notifications), but only your update which has now vanished (I assume you deleted it).
    I suspect the issue is that you need to correct your /etc/hosts file. Generally this would need the loopback line adding the host name:
    127.0.0.1 localhost localhost.localdomain localhost4 localhost4.localdomain4 mxcserver mxcserver.yourdomain.com
    Or if you have a fixed IP address, you could have a specific entry for the machine on a separate line (of course, the hostname/domain name needs to be your own).
