  3. Request for Support with CDF Update Issue after importing...
  • Subscribers 136
  • Views 4312
Request for Support with CDF Update Issue after importing .spi file in virtuoso
yogeshjaiswalCAD
yogeshjaiswalCAD 10 months ago
Greetings Andrew & Aurel,
I hope you’re having a wonderful start to the new year! I’m reaching out for your assistance with a CDF update issue.
Thanks for always being there for help..
Problem Statement:
I imported several library .spi files as schematics using the "Import .spi file" option in Cadence Virtuoso. After the import, I noticed that a specific parameter (CDF) of a transistor was not updated.
I have checked the original libaray & imorted libarary , there is a clear mismatch of  Wfg parameter.
For example
Clean library :
CDF parameter of mos
Wfg = 140  nm
w    =   140 nm
Imported .spi  library :
Wfg = 100  nm
w    =   140 nm
my skill code for CDF update
let((libName cdfId oldParam)
libName = "STD_CELL_SPI"
foreach(cell ddGetObj(libName)~>cells
cdfId = cdfGetBaseCellCDF(cell)
when(cdfId
;; Use cdfFindParamByName to locate "Wgf"
oldParam = cdfFindParamByName(cdfId "Wfg")
when(oldParam
;; Create "w" and transfer ALL necessary attributes
cdfCreateParam(cdfId
?name "w"
?prompt oldParam~>prompt
?defValue oldParam~>defValue
?type oldParam~>paramType
?display oldParam~>display
?callback oldParam~>callback
?units oldParam~>units
?choices oldParam~>choices ; Added: essential for cyclic/radio
?parseAsNumber oldParam~>parseAsNumber
?parseAsCEL oldParam~>parseAsCEL
;; Correct way to delete: cdfDeleteParam is valid if defined,
;; otherwise parameters are typically managed via cdfId~>parameters
cdfDeleteParam(oldParam)
;; Save the base CDF changes to disk
cdfSaveCDF(cdfId)
printf("Updated %s: Wfg changed to w\n" cell~>name)
Could you please share the Skill code or method to update the Wfg parameter to 'w'? This will ensure that the total width of the transistor is set to the width of the finger, as this discrepancy is causing an LVS issue in the imported cell from the .spi file.
I will be grateful for your help. Please help in !
Thank you for your help!
With Warm Regards & Cheers,
Yogesh Jaiswal
  • RobMan
    RobMan 10 months ago +1
    Hi Yogesh, Please ensure enable trigger callback in the 'Input' tab... Rob.
  • yogeshjaiswalCAD
    yogeshjaiswalCAD 10 months ago in reply to RobMan +1
    Thank you, RobMan. I did that in the first place while importing the .spi file, but the problem persists. If you can suggest some skill code modifications or share your skill code, that would be…
  • RobMan
    RobMan 10 months ago in reply to yogeshjaiswalCAD +1
    Andrew has written some code to trigger the callbacks... How to call CDF callbacks procedurally from SKILL to update CDF parameters? In this instance though it's unclear on what the dependency might…
  • RobMan
    Hi Yogesh,
    Rob.
  • yogeshjaiswalCAD
    Thank you, RobMan.
    If you can suggest some skill code modifications or share your skill code, that would be a great help!
    Thanks again,
    Cheers!
    Yogesh
  • RobMan
    In this instance though it's unclear on what the dependency might be. If you tweak the 'w' (e.g. 150) on the schematic does the 'Wfg' update?
    Rob.
  • yogeshjaiswalCAD
    Rob,Thank you for your help.
    However, I'm still facing the same problem. I would appreciate it if Andrew and Aurel could also provide their insights on the cause and potential solutions.
    If you could help fix the skill code I've written, that would be a big favour.
    For example
    Clean library :
    Wfg = 140  nm
    w    =   140 nm
    Wfg = 100  nm
    w    =   140 nm
    My skill code for CDF update
    when(cdfId
    when(oldParam
    ?name "w"
    cdfSaveCDF(cdfId)
    Thanks!
    Andrew Beckett 10 months ago in reply to yogeshjaiswalCAD
    First of all, this is a community forum, so asking for a response (in your initial post) from specific forum members is a bit presumptuous (I'm on vacation too). Secondly, I would have given exactly the same answers as Rob did.
    Your code will not do what you want, as it is creating a new CDF parameter in the Base CDF itself. That's not your issue, and so your code is completely inappropriate. It's not a matter of fixing it but throwing it away altogether.
    The right answer is one of the approaches that Rob suggested. You didn't give any specific information about what the SPICE file looked like, what mapping you used, or which PDK you're using. However, I wonder whether there is an order dependency in the CDF callbacks. If so, try choosing the "For all parameters specified on the instance line" checkbox on SPICE IN (shown in Rob's screenshot above), or using the ?order argument to CCSinvokeCdfCallbacks to limit the callbacks to call (say) just "w" it might be calling the callback for Wfg first which then sets w from Wfg). You gave no information about what happened when you tried either approach earlier or exactly what you tried.
    OK, back to vacation time...
  • yogeshjaiswalCAD
    yogeshjaiswalCAD 10 months ago in reply to Andrew Beckett
    Greetings Andrew,
    Thank you for always being there to help! It really means a lot to me that you take time out of your busy schedule to respond.
    I am able to solve my problem with the help of some of your excellent articles, which guided me in the right direction.
    I have created a custom skill code procedure ( Wfg to w) along with the standard Cadence skill API code, as follows:
    • load("/home/yogesh/proj/YOGIs_SKILL/CCSinvokeCdfCallbacks.il")
    • load("/home/yogesh/proj/YOGIs_SKILL/CCSCdfCallbackEntireLib.il")
    • CCSCdfCallbackEntireLib("STD_CELL")
    I have succeeded in this quest with your help ...  The code is functioning as expected
    Once again thanks for warm gesture
    Have a pleasant day!
    Cheers & regards,
    Yogesh Jaiswal
